Activity Forums Adobe Premiere Pro Image squeezed on timeline only
  • Image squeezed on timeline only
    Posted by Rich Rosen on June 21, 2005 at 7:22 pm
    After capturing clips they play fine when clicked on in the bin, but when they are dragged to the timeline they have thivk black borders on the right and left sides and need to be rendered. Never had this problem before. Any suggestions? Thanks much.
    Rich Rosen replied 21 years, 3 months ago 2 Members · 3 Replies
  • Mike Velte
    June 21, 2005 at 8:49 pm
    Apparently the resolution of the video does not match your project settings AND you have selected “Resize clips to project settings”. If your source video has a different PAR (pixel aspect ratio) or the res is not 4:3, then Pro will squeeze or squish your video.
  • Rich Rosen
    June 21, 2005 at 9:04 pm
    The clips are 1.9, but the Sequence is 1.2. Resize is not checked. I checked it, got the same results.
    The pixel aspect ratio boxes are greyed out. PPro 1.5.
  • Rich Rosen
    June 22, 2005 at 4:37 am
    original parameters were 16:9 somehow.
