Activity › Forums › Adobe After Effects › Image size / format best practices
  • Image size / format best practices
    Posted by Bruce Gaber on January 30, 2014 at 6:01 pm
    OK, after my last totally arcane posting I have a truly newbie question.
    I just loaded a 40 frame 16 bit PSD image sequence (thinking I might want to do some subtle color work). And then I began to wonder if I was setting myself up for a big performance hit re RAM preview and rendering. Is this the case? Would it be better practice to work out the details of the project with a JPG sequence and then only pull in the heavy duty files just before color correction and final rendering?
    Thanks so much
    Bruce
    Photographer / Motion Graphics Artist
    Vision Rising
    vimeo.com/BodhiBruce
    visionrising.com
    Dance Without Reason
    Roland R. kahlenberg replied 12 years, 7 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    January 30, 2014 at 6:19 pm
    With JPEG, your color work will be compromised. It’s best to work with the same color fidelity as the final files. I suggest that you instead work with proxies, which are a smaller or lower resolution (pixel-wise) relative to the final files. Take a look at this COW Tutorial here – https://library.creativecow.net/articles/hamad_serge/proxies.php
    Having said that, since you only have a small number of frames, you might as well just go ahead and work with the final files, from the very start. I doubt that your system will be greatly troubled by RAM previewing 40 frames. As and when required; when RAM Preview fails to render the entire Work Area, you can always reduce the comp resolution and zoom values.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Bruce Gaber
    January 30, 2014 at 8:14 pm
    Thank you very much. This is useful–and liberating–information.
    Bruce
    Vision Rising
    visionrising.com
    February 3, 2014 at 3:35 pm
    Bruce, I’m glad you found the information useful.
    Cheers
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
