image size
This may be a dumb question, but I need to cut several files together that are 320X240 files. My approach has always been to use stream clip to export them as 640X480 8 bit uncompressed files, and edit that size in a FCP sequence. The ultimate goal is to combine these files into one long clip and export them as a 320 X 240 mpg file for web use.
Is this the best method, or should I just leave them at their native size and edit them in a 320X240 sequence?
