Activity Forums Adobe After Effects image sequences out of order on import
  • image sequences out of order on import
    Posted by Chris Miller on July 19, 2007 at 11:37 am
    Hi
    I want to import 1800 images. They are in sequence in the folder on hard drive but when I import into AE 6.5 on a mac they are out of sequence… for eg 1029 is then followed by 103
    Can I fix this in AE on import?
    thanks
    wilko
    Jason Brown replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jason Brown
    July 19, 2007 at 1:32 pm
    Sounds like a file naming issue…how PC works (I don’t know about MAC) is:
    0001 comes before 01
    I’ve found that if my highest numbered file is a 5 digit filename, I need to start with 00001.
    The way to *fix* this is to use a utility…I downloaded and used this freeware for my PC…I don’t know if it will work on a MAC.
    https://www.snapfiles.com/get/bulkrename.html
    It will allow you to *insert* characters into a file name.
    HTH
    -JB
