Activity › Forums › Maxon Cinema 4D › image sequences on multiple objects
  • image sequences on multiple objects
    Posted by Kevin Cook on September 6, 2011 at 6:55 pm
    C4D12…If I use one image sequence and map it on 100 objects in my scene, is C4D loading the image sequence 100 times or once?
    Kevin Cook replied 15 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 6, 2011 at 10:46 pm
    I think the image sequence will only be loaded once, but I guess you could check by doint it each way and looking at system resources.
  • Kevin Cook
    September 6, 2011 at 11:00 pm
    I didn’t think about that I’ll check it out…also, if I used render instances of the object, I’m assuming that it would definitely only use the image sequence once? The object is just a one polygon plane (although there will be about 20 different versions) but will be repeated in my scene a couple hundred times. I just don’t want to get too far in and find out that my scene file becomes unmanageable.
