Image sequence workflow suggestions
I’m running the enterprise edition with Worker on a media server. I’ve set up a watchfolder that moves an image sequence of approx 3000 images into a catalog named after the scene description. I’ve got the watchfolder actions programmed to auto populate fields and folders based on the original folder name (ProducerName-ClientName-ProjectName-SceneName). Currently I have the “Import Media As” option set to Automatic in the Pre-processing section. When I set it to Image Sequence I get an error notice saying “Failed to save config: Sorry, you cant move or rename the original file when using the Image Sequence Importer because that importer affects multiple files.”
Can someone clarify how to use the Image Sequence option in a situation where I want the DSLR files to be moved from a watchfolder to a permanent folder.
My understanding is that by using the Import Media as Image Sequence option, the sequence is represented as one clip in the catalog rather than 3000 files. Is that correct? Is there a better way?
