Activity Forums Apple Final Cut Pro Legacy image sequence won’t import single frames
  • image sequence won’t import single frames
    Posted by John Graves on June 12, 2011 at 3:40 am
    I rendered out of AE as still images for max quality. The FCP help section said “make a new sequence and drag the folder onto the insert button”. Big problem is, each still image is taking up seconds a piece. I just want each still image to occupy 1 frame of the sequence. What am I doing wrong?
    thx
    ~ John
    “Life is good, as long as it doesn’t take up too much of my time.”
    -anonymous gamer
    John Benson replied 13 years, 2 months ago 4 Members · 5 Replies
  • Shane Ross
    June 12, 2011 at 4:20 am
    FCP doesn’t import image sequences. You use QT Pro to do this. It has the option.
    Shane
  • Patrice Freymond
    June 12, 2011 at 8:44 am
    In the Preference menu (alt Q), change stills duration to 1 frame, then import. Don’t forget to change back to a few seconds or the next time you will generate a still it will only be 1 frame long.
    Patrice
  • John Graves
    June 12, 2011 at 3:55 pm
    Yes, Patrice, I know about that. Stills duration preference to 1 frame didn’t help. Each loaded still was at least 10-15x long.
    ~ John
    -anonymous gamer
  • Patrice Freymond
    June 13, 2011 at 10:03 am
    Hi just tried it here:
    1) had a folder with tiff images named in sequencial order, imported that in FCP, after having changed the stills duration to 1 frame
    2)cut some footage in a sequence (xdcam in this case)
    3)inserted the tiff sequence by dragging the folder to canvas overlay
    et voilà, each tiff frame is exactly one frame long.
    patrice
  • John Benson
    July 21, 2013 at 3:03 pm
    I think there’s still a bug with FCP X (10.0.8) – for one, no “frame” duration in the prefs so you need to import as a fraction of a second (what’s up with that?) and even when you do it’s 10 seconds. Unless I’m doing something completely wrong. I’d love to hear if this actually works and what I need to do to fix it.
    thanks
    jrab
