Activity Forums VEGAS Pro Image Sequence Script
  • Image Sequence Script
    Posted by Steve Ashley on October 19, 2012 at 3:05 pm
    I have 1000+ folders containing 1 image sequence each, that are all the same length. I want to have a vegas file in each of these folders with just that image sequence imported and on the timeline for nesting purposes in later projects.
    Currently I’ve copied a blank veg file to each folder, and then using the crtl+o command to import the sequence, by pointing to the first image, selecting image sequence, and then confirming the next dialogue box, but after 50+ this has become incredibly tedious.
    I’ve found the Media AddImageSequence method in the Vegas API documentation but have no idea how to use it. Is it possible that could help speed up my process?
    Another solution I’ve tried but can’t figure out how to implement is telling vegas the source of the media is “/renders” instead of “C:/project/File1/renders” and I was hoping to name all of the image sequences the same and just copy the same Veg file to each unique file folder after pointing it to a sub directory. But because vegas is using a full path in the import media command it always points back to the first file.
    Any Suggestions to save me some time?
    Paul Beller replied 13 years, 10 months ago 2 Members · 3 Replies
  • Paul Beller
    October 20, 2012 at 11:02 am
    i got stuck at the very beginning? one image sequence??? what is that supposed to mean?
  • Steve Ashley
    October 20, 2012 at 1:42 pm
    Thanks for your response, Paul. One image sequence is a series of images that have the same name, followed by a sequential series of numbers. Two image sequences would be two differently named files followed by a series of asending numbers that may, or may not share the same number of files. I hope this clears things up. If you get stuck again trying to assist me I would be more than happy to clarify anything.
  • Paul Beller
    October 21, 2012 at 6:05 am
    all right, got it now. this number mislead me. so you don’t have 1 image sequence, you simply have AN image sequence in each of a 1000+ folder. i assume you plan to use those sequences pretty often. if only occasionally – you should be aware it is a waste of time, it is better to leave it as it is and import it ‘normally’, any time you need to…
    i’ve been scratching my head for awhile and sorry i can’t do it the way you want it. BUT i want to propose a kind of workaround, maybe even more useful-depends on how you want to use it. the condition is that all sequences have exactly the same length and you say they do.
    so… if i had a problem like yours and i couldn’t figure it out in a better way i would…
    make a new folder
    copy all your graphic files that make your sequences into the new folder. of course don’t go 1000+ times to each folder to copy files. you can do it with few clicks by going to the parent folder and search for an extension (so you will have to do it more than once if you have graphics with different extensions – i assume you are not) and just drag the result of the search to the new folder created in step one.
    make sure your files are in ascending order.
    select all and rename all files, windows explorer ‘rename’ command will do just fine.
    now you truly have 1 image sequence. it probably is gigantic…
    equip you vegas in ultimates pro. demo will do but i advise to buy it for future use – wonderful script machines. excalibur could probably do the job too.
    import your gigantic sequence into vegas, drop it on the timeline.
    use ultimates to create regions of a length of ###frames. as you say all sequences are of the same length so you can go automate for this.
    save your veg project.
    that is it, that is all… but not all… now you can chop at regions to have your sequences separate on the timeline, you can create markers to organize them, you can group your sequences by grouping tracks or by saving types of sequences in separate veg projects (flowers, cars, horses, sky etc.), you probably can create subclips from those groups, you can embed markers in it to organize even better – the sky is the limit. any time you want to add your sequence to another project, you just open the veg project, find the sequence (you would have to do it anyway) and you just copy between projects as all your sequences are events.
    as i said it is not exactly what you’ve asked for. i hope it is sth better. or i hope it is a kind of a brainstorm leading you to your optimal solution.
    cheers
    paul
