Activity Forums VEGAS Pro Image sequence problems
  • Image sequence problems
    Posted by Steve Roberts on October 26, 2011 at 3:02 am
    Hi again,
    It’s great that we can use image sequences without memory issues now (vegas v 11) but something new has raised it’s ugly head.
    I’m using several 500 frame PNG sequences. Each time I open the veg file I have to relocate them as it’s says they are missing. So I do this but only the first one that I relocate loads and the others are listed as off line ??
    This has happened on other occasions but it’s really annoying me now. I have deleted and replaced the images but when I reopen it’s still has problems.
    I use the PNG format as it has an alpha channel and lossless compression – a great format !
    Any leads ?
    Steve R.
    Amongst Projects
    ——— Sound, Visual and Electronic Content
    projects.amongstmyselves.com
    Tyson Onaga replied 14 years, 10 months ago 2 Members · 3 Replies
  • Tyson Onaga
    October 26, 2011 at 11:02 pm
    I know of no automated way to do this. You could put Markers into the Timeline which indicate where each image should go. You would then have to drag the image (one at a time) from the Media Pool to correct Marker location.
    You could try this:
    1. Get a list of the files you want added sorted by time (preferably). You could use something like “dir /od/b *.jpg > dir.txt”.
    2. Open Excel. Tools -> Macro -> VB Editor.
    3. Enter:
    Function MyGetFileDateTime(fileName As String) As Date
    MyGetFileDateTime = FileSystem.FileDateTime(fileName)
    End Function
    4. On the worksheet, copy the values of (1) into col A.
    5. In cell B1, enter:
    =PERSONAL.XLS!MyGetFileDateTime(A1)
    6. Select B1. Format -> Cells -> Time. Select the Type 30:55.2
    7. Copy B1. Select all the rows in B for which you have a value in col A. Paste. You should now have all the file date/time values in col B for each value in col A.
    8. Col C, cell C1, enter 0
    9. Cell C2, enter:
    =B2-Bx
    Yes, you’ll get an error.
    10. Copy C2. Select all the rows from C3 down for which there’s a value in B. Paste. You should now have a bunch of error-ed functions.
    11. Select the error-ed functions. Edit -> Replace. Replace Bx with B1. Each C2 (onwards) should be =B#-B1. I.e, C1 is 0, C2 onwards is the offset in time from 0.
    12. Highlight values in C, Format -> Cells -> Time. Select the Type 30:55.2
    13. In col D, enter a marker name (M.1, M.2, etc.) … or copy the values from col A.
    —> Col C and D should contain Time (offset) and Marker names
    14. Open your .veg
    15. Alt-6, Select Show Markers.
    16. Select the values from Excel, cols C and D. Copy.
    17. In Vegas (Markers) Select All (top leftmost cell). Paste.
    —> You should now have Markers in the timeline.
    Now it is time for drag and drop.
    Note: This assumes that time 0:00.0 is ALSO the start of your video. If it is not, you will need to adjust the time calculation functions accordingly. Alternatively, you could just slide the media in the images Track (forward or backward) until it lines up with your video footage Track.
  • Steve Roberts
    October 29, 2011 at 4:55 am
    Hi Tyson,
    Thanks for the reply but I’m not sure what you are replying to ???
    The problem I have is I can easily load a sequence of images. But the issues is that when I go to re-open the .veg file it can’t see the image sequence even though they are still in the original location.
    Steve R.
    Amongst Projects
  • Tyson Onaga
    October 31, 2011 at 2:06 pm
    Sorry, posted answer to the wrong thread. My answer was for this one:
    https://forums.creativecow.net/readpost/24/938072
