Forums › Adobe Premiere Pro › Image sequence in CS6
Derrick Lytle
June 10, 2012 at 2:09 amI have a folder of 175 images for a timelapse and I want to import them as an image sequence. I select the first image and then click the “image sequence” dialog box and then import. Premiere Pro compiles the images but it only gives me a 19 frame clip. What could I be doing wrong?
Jon Barrie
June 10, 2012 at 9:23 amimage sequences work on the same name structure with a tail that moves at a numeric increment of 1, so XXX_001, XXX_002, XXX_003 etc. It would appear that you have a frame number break after frame 19.
You can do a batch rename from Bridge, but you might want to try importing again from the next frame you can see that it has stopped connecting to.
Just remember that you need to have the sequence of single frames named in sequence 😛
Cheers JB
Jon Barrie
Adobe Video Solutions Consultant ANZ
Jon’s YouTube Tutorial Page
follow Jon with twitterDerrick Lytle
June 12, 2012 at 12:40 pmThank you so much! That was it. I figured it was something like that.
Log in to reply.
