Image Sequence framerate weirdness
Such a strange thing: I bring in a time-lapse image sequence shot on my DSLR… my project is set up on 24fps… the comp drops every 4th frame, and therefor on export i get a subtly jerky and nauseating clip.
Here’s the process: shoot a timelapse on my canon t3i with a remote timer. bring it into AE with import file. on inspecting the raw sequence all frames are there, but when brought into a comp at 24fps i can compare and every 4th frame is dropped.
The even weirder part (and maybe I’m just a super n00b and don’t know what i’m doing) when I set the comp frame rate at 29.97, the frames re-appear. Seems like it wants to be on 29.97 all the time, and at 24 it just drops frames to compensate, but I’d like to get it so that every image in the sequence appears at 24fps.
any clues would be SO helpful!! I’m trying to get a sequence that can be exported and brought into FCP for editing.
p.s. I’m on CS4. I’ve tried adjusting the global project settings and comp settings. Like I said, maybe I’m missing something obvious….-
