Activity › Forums › Adobe After Effects › image sequence export problems
  • image sequence export problems
    Posted by Sean on January 24, 2006 at 10:09 pm
    I’m working on a HD film with VFX and when I capture the plates at Sony HD 23.98 8bit then export an image sequence at the same frame rate, I get a duplicated frame every 30 frames or so in the sequence. So if the plate is 30 frames in length – the VFX house ends up with 31 and having to throw one away. At first I thought AE was doing this but then I inspected each frame in preview and sure enough there was a duplicate frame. (PS I’ve tried exporting 24 frames a sec and I got the same duplicate frame) Any clue what’s going on?
    Sean replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
