Activity Forums Adobe After Effects Image Sequence – 1 Frame Render
  • Image Sequence – 1 Frame Render
    Posted by Tony Moura on June 4, 2008 at 12:14 pm
    I have 63 jpg images and 63 separate text layers that I need a simple dissolve from one to the other. The entire sequence is 2:58. When I render it, only 1 frame is rendered?
    Joey Foreman replied 18 years, 3 months ago 3 Members · 3 Replies
  • Ron Coy
    June 4, 2008 at 4:04 pm
    what output module are you using to render it?
  • Tony Moura
    June 4, 2008 at 5:29 pm
    I was just adding it to the render que. Needed it to play as a looped video on a dvd.
  • Joey Foreman
    June 4, 2008 at 6:44 pm
    Check your work area; make sure it covers the entire sequence.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
