Activity Forums Web Design (WordPress, Joomla, etc.) Image scaling in liquid css layout
  • Image scaling in liquid css layout
    Posted by Donna Arbogast on October 28, 2009 at 12:40 pm
    Hello all. I’m looking for help on how to make my images scale to users screen size using a liquid css layout. I’ve searched the net, and I find lots of examples – but no one gives clear cut css coding directions.
    I’ve also tried different options (and combinations of) like
    width = 100% – didn’t work
    width = auto – didn’t work
    height = auto – don’t know if it worked
    max width = 1000 px – didn’t work
    Any advice you can give is much appreciated. Thank you!
    Jeffry Helms replied 13 years ago 6 Members · 15 Replies
  • 15 Replies
  • Curtis Thompson
    October 28, 2009 at 4:07 pm
    hello…
    w/o the context of the page it’ll be tough to offer a solution – do you have an example?
    sitruc
  • Donna Arbogast
    October 28, 2009 at 5:07 pm
    Of the page I’m building or just what I’m looking for in general?
    This is an example of what I’m looking for: https://www.rock-on-rock-on.com/
    My page isn’t anywhere near complete yet. 🙂
  • Curtis Thompson
    October 28, 2009 at 5:21 pm
    hello…
    hmm – sorry. i’m not seeing what you’re trying to do there. what on that page is the thing that you are trying to replicate?
    sitruc
  • Donna Arbogast
    October 28, 2009 at 5:31 pm
    If you drag the corner of the page in and out, you can see the image of the guy sitting by the rocks grow & shrink while staying in proportion to the page.
    I’ve used liquid layouts before – often actually – but I’ve never been able to figure out how to make the image scale with the page.
  • Curtis Thompson
    October 28, 2009 at 6:29 pm
    hello…
    ahh – ok. well – the beauty of the web is you have access to all his source code and you have a working example there…if you inspect that element, you’ll see:
    <div class=”centerimg”><img src=”images/home/billdan2.jpg” alt=”Balancing Rocks at Crissy Field July 5, 2003″ /></div>
    and then you can see the related css bits in the style sheet:
    https://www.rock-on-rock-on.com/styles/index1style.css
    i’d try a real basic page using that html/css combo and you’ll probably get it…
    hope that helps!
    sitruc
  • Donna Arbogast
    October 28, 2009 at 8:33 pm
    Curtis,
    1 – how did you find the css?
    2- it didn’t work. i copied his attributes except for his alignment & margins. the image still isn’t scaling.
    here is my html code for the image:
    Here is my css class code:
    .scaleImg {
    width: 100%;
    position: relative;
    float: right;
    Do you see something I missed?
    If it would help you to look at my page I can upload it. It’s just very preliminary & you know the whole artist “it’s not ready to be seen yet!” ego thing. 🙂
    Should probably mention, I tried entering a min. width & it stayed at that size. When I remove the min width, it blows out the side of the browser window & doesn’t scale.
  • Donna Arbogast
    October 28, 2009 at 8:36 pm
    Well that’s weird. the html didn’t show up. Try something different
    div class=”scaleImg” img src=”images/prettygirl.jpg”/ /div
  • Curtis Thompson
    October 28, 2009 at 9:02 pm
    hello…
    [Donna Arbogast] “1 – how did you find the css? “
    the link to the file is in the source of the page…
    here’s a simple example that i made which uses all his css and his image:
    https://sitruc.com/cow/img_scale/
    all the css needed is in the page so if you view the source you’ll see it there…
    hope that helps!
    sitruc
  • Fernando Mol
    October 28, 2009 at 10:50 pm
    When you paste code be sure to select it and press the CODE button on the post window (in the upper part) that way the code will show.
    *Remember to share a link to your site and to rate the posts. This is a free service for you and for us.
  • Fernando Mol
    October 28, 2009 at 10:57 pm
    Hi, Curtis and Donna
    I really got caught on this post. I tried to simplify the CSS Curtis used to find out exactly which properties made possible the image to stretch. I ended with this:
    #images {
    width: 75%;
    #images img {
    width: 90%;
    Note that I only tested it in Firefox.
