Activity Forums Apple Final Cut Pro Legacy Image safe being projected
  • Image safe being projected
    Posted by Brian Pitt on November 8, 2006 at 8:07 pm
    I am working on a project that is going to shown at a convention via projection on a 16 x 12 screen. The project is a minute long graphic animation that is going to open up the show. Here is my question: How do image safe areas relate to what will be visible on the screen? I know that if this was going to be deliverd for broadcast, I would need to stay inside the image safe area. But I need to be able to go RIGHT to the edge of my canvas without anything being cut off in order for this to work out the way I need it.
    Brian Pitt replied 19 years, 10 months ago 2 Members · 3 Replies
  • Brian Pitt
    November 8, 2006 at 8:35 pm
    If I kick the video out to my external monitor in underscan mode, the top and bottom of my entire canvas is safe, but is it cutting off a small portion of the left and right sides…
  • Andreas Karoliussen
    November 8, 2006 at 9:22 pm
    All depends on the projectors quality and how its adjusted (both regarding to the luma and colour space and what the projector shows…)
    Although normaly a projector (if correctly adjusted) shows what you see in underscan mode on your videomonitor.
    If you have the opportunity to play a dummy/test on the projector before the convention, Id consider that.
    [Brian Pitt] “the top and bottom of my entire canvas is safe, but is it cutting off a small portion of the left and right sides…”
    1)If its so that you see more in your canvas in final cut then on your monitor:
    Try adjusting horisontal display on your videomonitor.
    and if this dont work:
    Which contacts do you use from your Mac to the videomonitor?
    2)If its so that you cant see all your graphics in fcps canvas:
    check your export settings match fcps settings (square pixels/nonsquare pixels for instance)
    hope this helps you out!-)
    Andreas
  • Brian Pitt
    November 9, 2006 at 7:13 am
    Thanks for the response. That should help me out…
