Activity › Forums › Apple OS X › Image Restore failure
  • Image Restore failure
    Posted by Chriswood on April 20, 2006 at 7:18 pm
    I created a .dmg file and have tried to restore it to my primary HD by booting to both the Install DVD and a bootable firewire drive. When I launch the Disk Utility and try to restore the .dmg file it gives me the error “No such file or directory” even though I can select the image file. If I try again it then tells me the resource is busy.
    I have also tried restoring to an external USB drive but get the same results using 2 different disk image files.
    Thanks for any help
    Thanks for the help
    Tiga
    Chriswood replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
