Activity › Forums › Adobe After Effects › image quality when creating a magnifying glass in AE
Posted by Julia Calbetó on January 6, 2013 at 1:29 pmHello!
I did a magnifying glass in AE using the Bulge and Magnify effect. The problem I have is that the image magnified (120%) doesn’t have enough quality and appears blurry. I tried with different image sizes and formats, but it is always the same and I didn’t find anyone talking about this issue, please help me!!!
Hans Castrop replied 13 years, 8 months ago 4 Members · 26 Replies -
Julia Calbetó
January 6, 2013 at 1:50 pmI found one solution but I don’t really understand it since I am a beginner with AE:
“The effect probably doesn’t honor the continuous rasterize setting. One option is to precomp your illustrator file, then double that nested comp’s size (and scale up the illustrator file, with continuous rasterization). At that point you can scale the nested comp down to, 50% and reposition it so it matches how it looked before.”
Julia Calbetó
January 6, 2013 at 6:25 pmI tried it and it’s still blurry… any other ideas?
Thanks!!! -
Herbie Humperdink
January 6, 2013 at 7:01 pmHey Julia,
Make sure the image you want to magnify using the bulge effect is big enough so you can scale it down a bit before you use the bulge effect. Any time you use some form of distort that scales the the layer beyond 100% it will have some quality loss. The trick is to start with a bigger better quality image so it’s not noticeable.
Julia Calbetó
January 6, 2013 at 8:05 pmHello Herbie, thanks for your response.
The image I imported has 4111×5486 px and a resolution of 200ppi, and I scaled it down to 535×717 px, I think it is big enough, isn’t it?
But it’s still blurry… -
Herbie Humperdink
January 6, 2013 at 8:08 pmThat is huge it should be good. when you scaled it down, did you precomp it? It should not be blurry.
Can you post a link with a screen grab?
Julia Calbetó
January 6, 2013 at 8:17 pmTrying to follow the instructions I posted before, I did sth like precomp but I didn’t really know what to do next. Can you explain this step to me please?
Thanks! -
Herbie Humperdink
January 6, 2013 at 8:27 pm -
Julia Calbetó
January 6, 2013 at 9:24 pm -
Herbie Humperdink
January 6, 2013 at 9:30 pmWhat is the scale on that?….when I asked if you did precomp it was because if you layer (layer 20) is scaled at a 100% anything beyond that would blur.
Another alternative is to ditch the bulge all together and just use a traveling matte that uses a bigger version of your graphic to reveal as it.
