Activity › Forums › Adobe Premiere Pro › Image quality problem in progressive mode
  • Image quality problem in progressive mode
    Posted by Valter Gurfinkel on July 5, 2009 at 5:32 pm
    Hello, experts
    I’m making a HD video using Premiere Pro CS4 as editor and Encore to build a Blu-Ray disk.
    The format is 1280X720p and the rendering was done by the Adobe Media Encoder in 23.976 fps.
    The format is 720p because my HDTV is a little old Sony Bravia, thats only supports 720 in the progressive format, and I used 23.976 fps because it is accepted as “legal” by Encore for this progressive format that’s doesn’t require retranscoding.
    All the clips were recorded in HD and using NTSC 29.97 fps.
    The whole workflow finished without problems, but the video when seen in TV doesn’t show a flowing and smooth movements, but something “hard” similar as a slight “strobe” effect.
    I understand that the difference of frame rates can be the cause of this result, but I would like to know if there is a way to resolve it, maintaining the smoothness of movements in the progressive format.
    Valter-Brazil
    Valter Gurfinkel replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
