Image Quality Difference In Preview Window vs. Sequence
I am having an issue getting my image quality from my preview window to match the image quality once it is dragged into the sequence.
The footage I am working with was recorded in AVCHD 1080i with a Panasonic AG-HMC 40. It was then imported through Final Cut Express 4.0.1 and compressed with the Apple Intermediate Codec. The footage was edited in FCE then exported to 720×480, 29.97 fps, no compression.
I imported this footage to Premiere Pro CS5. In the “Viewer” or “Preview” window, the footage looks wonderful. I drag it into my sequence on the timeline and it looses quality. The color is degraded and there are motion blur (interlaced?) lines that appear. When I match these two clips up side by side in the viewer and canvas (the premiere equivalent) the loss of quality is very apparent.
The clip properties are as follows:
Image Size: 720×480
Pixel Depth: 32
Frame Rate: 29.97
Average Data Rate: 39.5 MB/Second
Pixel Aspect Ratio: 1.2121The Sequence properties are as follows:
720×480
29.97
48000 HZ-StereoWhy am I losing quality when I drag this clip to the timeline?
Andrew
