Activity Forums Adobe After Effects Image Problem with Cont Raster On – HELP!
  • Image Problem with Cont Raster On – HELP!
    Posted by Jeffrey Fitzgerald on March 9, 2009 at 3:47 pm
    Hey Gang, I have a document that originated in InDesign. It is a collection of images, and I saved it as a PDF to import into AE. Without Continuously Raster turned on, the images are junk close up.
    But with it enabled they look great. BUT, when any movement is rendered, the images jump around as if they were non anti-aliased and almost appear to wiggle. I know that the render order changes when using that switch so any help is much appreciated. I have an hour to get it right :-)!
    Thanks for any help or advice…
    Jeffrey Fitzgerald replied 17 years, 6 months ago 27,128 Members · 2 Replies
  • Jeffrey Fitzgerald
    March 9, 2009 at 7:33 pm
    I think ID is both a vector and bitmap process. But the weird thing is that even though the PDF of the images is raster, turning on the switch makes the quality double. But it’s when there is motion that is when the problem is seen.
    March 9, 2009 at 7:36 pm
    “I’m sorry to be the bearer of bad news, but you’re sunk.”
    Your in hard news, couldn’t you just do the “this just in, headaches on the rise in Adobe user community” story again…
