Activity › Forums › Panasonic Cameras › Image problem after listing and transfer
  • Image problem after listing and transfer
    Posted by Alex De la manche on May 28, 2010 at 2:33 pm
    Hello,
    P2HD with my camera card, I filmed HD 720p 25ips
    The rush ds file 'content' of the card has a picture perfect but when I list and transfers ds FCP , The same image has a slight effect when there is a movement stromboscopique.
    The result is the same after exporting in mov or mp4.
    I said that I ride with FCP 6.6 MAC OS X 10.4, On Mac Book Pro, With a hard drive 2 tb 7200 rpm , Connected esata.
    I have never encountered this problem when I was getting into DV.
    Can you explain what the problem is and what is the solution to this problem?
    Thank you! 🙂
    John Fishback
    replied 16 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    May 28, 2010 at 9:47 pm
    Are you monitoring on a computer screen or a broadcast monitor? The computer may give you this effect while a broadcast monitor might not. Can you post a frame? Is it tearing, or is it more a vibration? Is it a moire effect? This link explains moire patterns. They happen with closely spaced patterns.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
