Activity Forums Adobe After Effects Expressions Image path problem in After Effects script.
  • Image path problem in After Effects script.
    Posted by Joshua Faget on September 26, 2016 at 7:03 am
    Hello,
    I have the following problem. When I run my script from File>Scripts>MyScript it works, but when I open it from Windows>MyScript as a dockable panel it says that the image doesn’t exist.
    What I want is to tell After Effects to look in “[after effects folder]/Scripts/aCustomFolder/icon.png”
    What am I doing wrong?
    var myButton= mainGroup.add("iconbutton", undefined, image="./Scripts/(ImageAssets)/MyButton.png");
    Xavier Gomez replied 9 years, 11 months ago 4 Members · 4 Replies
  • Miguel De mendoza
    September 26, 2016 at 8:25 am
    If you are running as a dockable panel, your script may be in Scripts/ScriptUI Panels. This notation “./” represents the current directory. If your “(ImageAssets)” folder is inside Scripts folder, you can access like this “../(ImageAssets)/MyButton.png”, wher “../” represents the parent folder of where the script is.
  • Joshua Faget
    September 26, 2016 at 9:27 am
    Hello,
    When I run my script from “ExtendScript” with this:
    var myButton= mainGroup.add(“iconbutton”, undefined, image=”./Scripts/(ImageAssets)/MyButton.png”);
    It works, but when I save my Script and place it in the Scripts folder AND in the ScriptUI Panels folder … it stops working.
    If I change it to
    var myButton= mainGroup.add(“iconbutton”, undefined, image=”./(ImageAssets)/MyButton.png”);
    it doesn’t work neither when I run it from the Scripts folder nor when I run it from ScriptUI Panels folder…
    What I am trying to achieve is to avoid “C:/Program Files…etc”
  • Jakob Wagner
    October 3, 2016 at 1:10 pm
    I do something like this, maybe it’s what your looking for:
    var scriptPath = File($.fileName).parent.fsName;
    var imagePath = scriptPath+”/myfolder/imagename.png”
    – Jakob
  • Xavier Gomez
    October 3, 2016 at 1:21 pm
    fsName is mostly for display i think.
    To make sure that your path will work on any system, absoluteURI is better:
    var scriptPath = File($.fileName).parent.absoluteURI;
    or (same result):
    var scriptPath = File($.fileName).path;
    then when appending the relative path, it’s better to escape the added string:
    var imagePath = scriptPath + encodeURI("/myfolder/imagename.png");
    Xavier
