Activity Forums Adobe Premiere Pro Image Pan in Premiere 2.0
  • Image Pan in Premiere 2.0
    Posted by Rudycassol on October 10, 2006 at 7:45 pm
    I used “image pan” under Video Effects/Transform in Premiere 6.5 quite frequently. I recently upgraded to Premiere Pro 2.0, but “image pan” isn’t available anymore. Does anyone know where it was renamed/moved to? or is there an equivilent method that is as quick as “image pan”?
    Thanks in advance,
    Rudy
    https://dallasmontage.com
    Steven L. gotz replied 19 years, 11 months ago 3 Members · 2 Replies
  • Blast1
    October 10, 2006 at 10:26 pm
    [rudycassol] “I recently upgraded to Premiere Pro 2.0, but “image pan” isn’t available anymore. Does anyone know where it was renamed/moved to? or is there an equivilent method that is as quick as “image pan”?”
    Its called “Motion Controls” now,after the image is on the timeline click on the image and select the Video Effectts tab thats with the Source monitor and Audio Mixer tabs above the timeline, you will see the Motion Control effect. For further info use the Premiere help under M
  • Steven L. gotz
    October 11, 2006 at 3:54 pm
    One problem with Premiere was that you could not use motion for image panning. In Premiere Pro that was fixed so keyframing Position and Scale in the Motion Effect works great. Just don’t use the option to automatically scale the image.
    Steven
    https://www.stevengotz.com
