Activity Forums Apple Final Cut Pro Legacy image output problem
  • image output problem
    Posted by Dan Newton on March 12, 2010 at 8:09 am
    I have a small problem —
    i have an image that i converted to PNG FORMAT
    Now when i move the image from left to right — when i output the image the image looks all shaky — why is that —
    I even tried in after effects and the same thing happens —
    Please Help?????
    Rafael Amador replied 16 years, 6 months ago 3 Members · 3 Replies
  • Shane Ross
    March 13, 2010 at 1:10 am
    Deinterlace it. Either before you export it, or after, with Photoshop or similar.
    Shane
  • Dan Newton
    March 13, 2010 at 10:47 am
    Thanks for getting back to me —
    If I interlace it in Final Cut — what should it be —
    1. UPPER ( ODD )
    2. LOWER ( EVEN )
    3. FLICKER FILTER ( MINIMAL )
    4. FLICKER FILTER ( MEDIUM )
    5. FLICKER FILTER ( MAX )
    Kind Regards,
    Dan
  • Rafael Amador
    March 13, 2010 at 12:04 pm
    If is a video frame that you have exported as PNG and your footage is interlaced, you need to de-interlace it before exporting.
    If is an still or graphic that supposed to be Progressive, check it as Field Order NONE in the Browser and lie it again in the sequence.
    Rafael
    http://www.nagavideo.com
