Activity Forums Apple Final Cut Pro Legacy Image not opening upon importing
  • Image not opening upon importing
    Posted by Jeff Wilmes on April 8, 2008 at 2:08 pm
    Trying to bring logo into FCP from Photoshop. I’ve taken a jpeg and cut the white background out. I have the logo on a transparent background and importing into FCP. When I try to open file, I get this message “Codec not found. You may be using a compression type without the corresponding hardware card.” “Error: Out of Memory.” I’m saving as psd.
    I have done this numerous times before without this message and not sure why now I’m havin this problem. I’m happy to give more info as this may not be enough for troubleshooting.
    Jeff Wilmes replied 18 years, 5 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    April 8, 2008 at 4:50 pm
    One thing that will cause the out of memory error is a blank layer in the psd file… make sure you don’t have any.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tom Wolsky
    April 8, 2008 at 4:59 pm
    Also make sure it’s not 16-bit per channel.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Chuck Reti
    April 8, 2008 at 5:08 pm
    If you don’t need the layers as separate elements, export as .PNG and see what happens (should work OK).
  • Jeff Wilmes
    April 9, 2008 at 1:42 am
    Thanks for the tips… file was 8 bit and only one layer. I cut the background so I just had the logo with transparent background , saved then imported. I must be missing something in photoshop as I save it to .psd, something for me to figure out later I guess.
    I used .png and it worked fine, thanks.
