Activity Forums Adobe Premiere Pro image moves between identical keyframes
  • image moves between identical keyframes
    Posted by Barbara Daly on July 11, 2017 at 12:11 am
    I’ve had this issue on more than one occasion. I have a photo on the timeline that I am scaling and changing its position. However, between the initial and final move I have two keyframes with identical parameters separated by about a second. This should create a static position for that second. However the image has some movement. I can not find where it’s coming from, what’s causing it or why. Any ideas would be very much appreciated!
    I’m using the latest adobe premiere pro cc updated June 2017.
    b
    Barbara Daly replied 9 years, 2 months ago 2 Members · 2 Replies
  • Ann Bens
    July 11, 2017 at 5:28 pm
    Set the keyframes to linear. That usually fixes the problem.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Barbara Daly
    July 11, 2017 at 7:04 pm
    Oh you are BEAUTIFUL! Thank you.
    Turns out one of the keyframes was set at Temporal interpolation: linear, but the Spatial interpolation was set at auto. Once I changed that to linear as well, it solved the problem. That’s awesome. Thanks so much!!
    b
