Activity › Forums › Adobe After Effects › Image Masks?
  • Image Masks?
    Posted by Jessica Chapman on April 24, 2010 at 4:36 am
    Hi there!
    Is there anyway that I can achieve an image mask in After effects?
    If not, is there another method I can try to achieve the desired result:
    My composition:
    Layer 1: Footage of outside scenery
    Layer 2: A Photoshop image of a volcano with an alpha channel.
    What I am trying achieve:
    Import the PSD volcano image with a mask attached into After Effects. I then want to hide the volcano image below the mask, and then animate the volcano image moving upwards to reveal itself.
    *Making the volcano image look as though it is coming out from the ground in the footage on layer 1.
    The mask has a rough texture to it, and using the pen tool instead to create a mask is not the look i am after.
    Thank you,
    Jess
    Jessica Chapman replied 16 years, 5 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 24, 2010 at 12:59 pm
    Check out track mattes — this feature lets you use an image as a mask.
    Walter Soyka
  • Jessica Chapman
    April 25, 2010 at 1:06 pm
    Thank you very much! 😀
    That’s exactly what I was wanting to achieve! 🙂
