Activity Forums Apple Motion Image in motion sequence goes back when adding lights
  • Image in motion sequence goes back when adding lights
    Posted by Jason Calhoun on February 23, 2010 at 7:24 pm
    I have created a motion sequence with multiple lights. I have a stock frame and drop zone within the sequence. For some reason the frame flickers from being visible to being black, as if the lights aren’t lighting it. The have some wriggle parameters on the camera and some of the lights. Any ideas?
    Zak Peric replied 16 years, 6 months ago 2 Members · 1 Reply
  • Zak Peric
    February 23, 2010 at 8:29 pm
    In the properties of the frame which flickers find lighting/shading change the parameters and see what happens. Also try changing the group from 2d to 3d.
    Also check the position of the frame in Z space (check the Z position of the group in which the frame resides).
    If this does not help. Delete the group with frame, create new group and place the frame image back, see if you have the same problem.
    I hope this helps…
