Activity Forums Apple Final Cut Pro Legacy image gets fuzzy during graphic fades
  • image gets fuzzy during graphic fades
    Posted by Clayton Light on August 8, 2008 at 8:33 pm
    I captured in DVC Pro 50. When graphics fade on or off the image goes fuzzy during the fade. This also happens during some transitions. I’ve tried everything I can think of. Is there a fix for this?
    Colin Mcquillan replied 18 years, 1 month ago 2 Members · 2 Replies
  • Colin Mcquillan
    August 8, 2008 at 9:25 pm
    In your “render all” drop down,
    SEQUENCE –> RENDER ALL –>
    is there a check-mark beside “FULL”
    If not, and if not on the other options, check them all and re-render using “Render All”.
    Colin McQuillan
    Van. B.C.
  • Colin Mcquillan
    August 8, 2008 at 9:27 pm
    [Colin McQuillan] “In your “render all” drop down,
    is there a check-mark beside “FULL” “
    You can of-course do this with “Render Selection” as-well
    Colin McQuillan
    Van. B.C.
