Activity Forums Apple Final Cut Pro Legacy Image Gain in FCP 7
  • Image Gain in FCP 7
    Posted by Andy Laviolette on March 16, 2010 at 6:55 am
    I recently switched to FCP 7 after years
    of being a Premiere user (CS4 on my MacBook Pro is just too buggy)
    and have a question regarding image gain. In Premiere I could take
    a clip, apply the “RGB Color Corrector” filter and could manually
    increase the image gain. This was particularly useful when shooting
    at +6db on my PMW-EX1 and quickly changing to 0db in the middle of a
    shot because I could use key frames to make the portion shot at 0db
    seamlessly match the gain shot at 6db. (I actually said that
    backwards…)
    Regardless, how can I increase the gain of the image without
    affecting the gamma, white levels, shadow/highlights, or anything
    that greatly compromises the blacks? I can’t believe such a simple
    problem has been so difficult for me to figure out, I feel like I’m
    starting from scratch all over again!
    Thanks for your time!
    Andy Laviolette replied 16 years, 5 months ago 2 Members · 2 Replies
  • Andy Mees
    March 16, 2010 at 10:00 am
    There is a Proc Amp filter in Effects > Video Filters > Image Control
  • Andy Laviolette
    March 16, 2010 at 4:45 pm
    Thanks for the reply! Unfortunately it seems as if the Proc Amp only affects highlights and the Gamma channel or something. If I push the Chroma up very much at all it washes out the blacks…even after a small adjustment. The Video slider appears to be affecting the saturation and the setup slider the gamma. Obviously the phase adjustment affects the color; what am I missing? What steps do you take if you have underexposed shots to deal with?
    Thanks so much for your time!
