Activity › Forums › Adobe Encore DVD › image for button highlight
Posted by Jim on July 2, 2006 at 4:53 amFor a highlight over a button, I set it to show an image, but in preview it shows up as a white box. I dont know what’s the problem. Please help, thanks.
John Cuevas replied 20 years, 2 months ago 3 Members · 2 Replies -
Jeff Bellune
July 2, 2006 at 12:09 pmSubpicture highlights are only 2-bit colors plus transparency. That limits you to a solid color shape. You can combine up to 3 solid-color shapes for a single button highlight, but that’s as far as you can go.
Images, mask feathers, effects, etc. from Photoshop can’t be used for the highlights directly.
To get around this, you can create duplicate menus that are activated automatically when the audience navigates to a button on the original menu. The duplicate menu can contain the image that you wanted to use as the highlight in place of the button on the original menu.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
John Cuevas
July 2, 2006 at 6:25 pmThis was posted by David Garret a little while ago. The tutorial there will help you out.
Date: May 26, 2006 at 2:33:23 am
Subject: Re: How could I add a photo to my subpicture layers ?look to Tutorial #9 of the advanced section of my site http://www.sitesled.com/members/doogs/downloads.htm it will show you how to go about it. Just adapt the process for your own needs (tutorial is for Encore 1.5
Johnny Cuevas, Editor
http://www.ckandco.net
