Activity Forums Adobe After Effects image flutters as it animates horizontally
  • image flutters as it animates horizontally
    Posted by Yamir Bhatt on July 20, 2005 at 1:44 pm
    I am animating an image of a model from left to right. when i render it in quicktime the edges of the image flutter like crazy. i tried using motion blur. but that blurs the image too much. any proven technique to over come this?
    Aharon Rabinowitz replied 21 years, 2 months ago 3 Members · 2 Replies
  • Aindreas Gallagher
    July 20, 2005 at 4:27 pm
    if you turn off m.blur & set the render output to interlaced, you’ll get very smooth movement.. (maybe too smooth? Tends to look like a dve move, in a way..)
    hth
    a
  • Aharon Rabinowitz
    July 20, 2005 at 9:30 pm
    Interlaced motion from left to right can look really mechanical, but sometimes you just have to go with it if you have the problem you mentioned.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
