Activity Forums Adobe After Effects Image disapearing in HD project
  • Image disapearing in HD project
    Posted by Chandra on March 25, 2010 at 9:10 pm
    I have an HD project (1920×1080) its a simple animation. I have a road I built that the camera flys down. Its a very large comp I made 25000×1500. that is then placed in the 1920×1080 main come and the camera moves down it. It was working just fine up until this morning when I did my final render. Now all of a sudden it will not show up when I view in full resolution. If I view my comp in Half it shows up fine. It also will not render in full, only in half. Suggestions? not sure what happened. It rendered fine a few days ago.
    thanks!
    Scott Novasic replied 16 years, 6 months ago 3 Members · 2 Replies
  • Bruce Wainer
    March 26, 2010 at 1:09 am
    Could OpenGL have been turned on? My graphics card makes layers disappear if they are too large or the effects are too complex
  • Scott Novasic
    March 26, 2010 at 3:59 am
    empty your cache as well. You are pushing the memory requirements which also may lead to anomalies.
    Also allow for half resolution stuff to show but not full. Also, if you are using a 3d camera check the
    aspect ratio setting. Too ‘fisheye’ a setting can lead to odd behavior as well. Open Gl can cause issues previewing, but final render should be fine.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
