Activity Forums VEGAS Pro Image crop doesn’t match preview or render
  • Image crop doesn’t match preview or render
    Posted by Daniel Johnson on July 15, 2019 at 4:16 pm
    I am using Sony Vegas Pro 13 to edit GoPro footage, and as part of a transition, I’m trying to crop a fish using the event pan/crop tool, but the image in the event pan/crop tool doesn’t match up to the image in the preview window or the render. The media dimensions, project settings dimensions and render dimensions are all the same, and I haven’t made any adjustments using the event pan/crop other than the masking. I also haven’t applied any media fx, other than some minor colour correction, and I haven’t used any stabilisation.
    If anyone could help, I would be extremely grateful, as it’s been driving me crazy. See the image as an example – in the event pan/crop window the fin (circled in red) extends out of the frame, but in the preview it’s fully within the frame
    Daniel Johnson replied 7 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Marco Baer
    July 15, 2019 at 6:33 pm
    Your Pan/Crop window and your preview window show different frames of the video.
  • Daniel Johnson
    July 15, 2019 at 7:17 pm
    It shouldn’t be – he ‘sync cursor’ option is selected, and adjustments I make to a keyframe show up on the preview, even though there is a keyframe for every frame. So if it is showing the wrong frame, I have no idea how to fix it.
  • Marco Baer
    July 16, 2019 at 8:48 am
    Take a look at the small fishes. They are totally different.
  • Daniel Johnson
    July 16, 2019 at 11:06 am
    That’s because I’m masking out the large fish, i.e. I’m making it appear in front of a different background. The small fishes are from an entirely different clip, which I’m transitioning into. So that therefore appears in the preview window, but not the event pan/crop window, which only shows the single clip
  • Marco Baer
    July 16, 2019 at 1:35 pm
    O.k., I see. Another cause for your finding could be different frame sizes between your source clip and your project. Do these size match?
  • Marco Baer
    July 16, 2019 at 1:36 pm
    Sorry, of course you already mentioned this in your first post – it does match.
  • Daniel Johnson
    July 17, 2019 at 7:28 am
    Yea I did at first think it might be that, but I made sure and they were in fact the same. Strangely enough, after restarting my laptop, the problem resolved itself, which is very strange, but a relief. Perhaps I had accidentally selected some strange view, which was then unselected when I restarted. However, I think I’d restarted before and it didn’t work, so I’m not sure.
