Activity › Forums › Adobe After Effects › Image buffer on 1 box
Posted by Anthony Dupsta on June 12, 2007 at 10:09 pmNot to beat a dead horse, I have done a search and read the archives on this issue. This just sounds like a
Roland R. kahlenberg replied 19 years, 3 months ago 2 Members · 3 Replies -
June 13, 2007 at 2:22 pmWeird eh? I would increase cache from 60 to 80 instead of lowering it.
Have you tried switching off previews with the CapsLock? Is the issue occurring consistently with one of the boxes and not the other – hardware RAM issue?
HTH
Roland Kahlenberg
https://www.broadcastGEMs.com – Adobe After Effects project files
https://www.myspace.com/rorkrgbspace -
Anthony Dupsta
June 13, 2007 at 5:48 pmYes it occurs consistently with the same box. The box that fails is very quick to do so. Yet the second works every time. The specs on the two boxes are exactly the same.
You could be right about one having unstable ram? That I don’t know.
If you have any other suggestions please let me know. I will continue to try diff cache settings, reboot and start the render.
Thank you for your replyDupsta
June 13, 2007 at 6:01 pmI know you’re not the IT guy but howzabout swapping the RAM chips on the two machines? That’ll be an instant answer as to whether it’s a hardware RAM issue.
HTH
Roland Kahlenberg
