Activity Forums Adobe After Effects image buffer error
  • image buffer error
    Posted by John Corino on February 5, 2008 at 9:46 pm
    I have been using a G5 for a long time and never had a problem in AE 7. I just got a Dell XPS 720 workstation and I am getting the “could not create 720 x 480 image buffer” error during all my renders. I have 4 gb of RAM with 2.5 GB being shown, (I was told my dual video card and other system devices are using 1.5 gb).
    I have been searching this forum and other sites for days trying to resolve this problem.
    I have selected the purge every _ frames and tried putting 5, 10, 50. Doesn’t fix it. I have lowered the cache size like has been suggested. I’ve purged the undos. I don’t know what else to do. I have checked my system monitor and the RAM usage increases throughout the render and once it gets to 2.4 GB, I get the error message. However, on my G5, the RAM usage does not go over 1.4 GB or so, so I’m wondering why it doesn’t level off on the PC?
    It’s pretty distressing because this is only an 8 second 720×480 clip, so its not big at all.
    Any suggestions and help is appreciated.
    Mike Gondek replied 16 years, 8 months ago 3 Members · 4 Replies
  • Darby Edelen
    February 5, 2008 at 10:42 pm
    [John Corino] “I have checked my system monitor and the RAM usage increases throughout the render and once it gets to 2.4 GB, I get the error message. “
    What are your Memory & Cache settings?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • John Corino
    February 5, 2008 at 10:53 pm
    I had it at: 120 % =2.0 GB for Max Memory Usage, 60 %=1.2 GB for max RAM cache size, and 8000 mb for Maximum disc cache. I have altered these and done some tests but nothing worked.
  • John Corino
    February 5, 2008 at 10:56 pm
    I turned off openGL and it still does the same thing-gives the error when it gets to 85% of RAM used during render.
  • Mike Gondek
    January 20, 2010 at 3:30 pm
    Anyone ever find a solution to this? I have have my max Ram & Max Memory set to 100%.
    I am on CS3 AE with 2gb ram, and am expereienceing the same error on a small 10 second clip.
