Activity Forums Adobe After Effects Image Buffer Error
  • Image Buffer Error
    Posted by David Fleury on September 14, 2007 at 6:56 pm
    I was hoping somebody could shed some light on this error message…
    After Effects error: unable to allocate space for a 14400 x 486 image buffer.
    You may be experiencing fragmentation. In the Memory & Cache Preferences dialog box, try decreasing the Maximum RAM Cache Size value and selecting the Enable Disk Cache option, increasing Maximum Memory Usage, or both. (7 :: 66)”
    I get it during render on two layers that are using the same sets of effects. Im pretty sure it is one of the animation presets I have on the layers. What can I do about this?
    I have tried the suggestions on the error message itself to no avail. I can post the entire render log file if anyone thinks it will help.
    Thanks!!
    Todd Kopriva replied 19 years ago 3 Members · 3 Replies
  • Kevin Camp
    September 14, 2007 at 7:08 pm
    enabling disk cache has usually helped me when i get that error. except when i use ae7 on a mac pro, particuarly with cc effects (although the error message is a little different, just a image buffer error). to fix that i usually have to restart ae7.
    you could also try edit>purge>all…
    what version, platform and effects are you using?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • David Fleury
    September 14, 2007 at 8:04 pm
    Actually clearing the buffers and restarting did the trick. Im not sure what the 14,000 is referring to? I dont have a layer nearly that big in the comp unless it is the stretch in preset that is triggering that.
    Thanks everybody.
  • Todd Kopriva
    September 15, 2007 at 5:55 pm
    Jonas Hummerstrand has a good blog post about this error and how to avoid it
    Todd Kopriva
    Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’
    After Effects Help on the Web
