Activity Forums Apple Final Cut Pro Legacy iMac Video Editing
  • iMac Video Editing
    Posted by Steve Kunz on June 21, 2011 at 3:57 pm
    I’m looking at different options for a computer that can effectively render high quality video. It also needs to be able to deal with video in large amounts (video clips over 1 hour long) I’m considering getting an iMac (specs: 2.5GHz Quad-Core Intel Core i5, 1920 x 1080 resolution, 4GB (two 2GB) memory, 500GB hard drive1, AMD Radeon HD 6750M with 512MB)
    Would this computer be sufficient for my video needs?
    James Vincent replied 15 years, 3 months ago 2 Members · 1 Reply
  • James Vincent
    June 21, 2011 at 7:49 pm
    depends if you are editing the raw encoded material or a low-res copy (example: ntsc or offline RT) if you are editing a low-res then definetly yes then when it is time to do effects, color correction etc. just batch/reconnect your media to the high-res matierial.
    -james
