Activity Forums Adobe Premiere Pro iMac Suite set up for review
  • iMac Suite set up for review
    Posted by Chris Detjen on June 17, 2013 at 6:45 pm
    Because we will be switching to Premiere Pro, I thought best to post in this forum. Our company intends to invest in a basic i-Mac suite and I’d like to field recommendations/advice based upon the flow chart I have created (link below).
    I have concerns about whether the outlined design will function as intended, or if there is a roadblock in this design that I overlooked. And whether the I/O device selected is sufficient for this setup. Secondarily is finding a good storage option. Media for the edit suite will be stored local, no network-based storage as of yet. Overall, need to keep costs somewhat low ($500-600 for the storage, and a similar range for the IO device).
    The core component is the IO. Looking at the Blackmagic UltraStudio Express as it appears to have all the connections needed to satisfy our needs outlined in flow chart and below:
    Monitors x3:
    –HDMI out to the wall TV for client viewing.
    –SDI out to our Panasonic BT-LH 1700 for the editor.
    –Tbolt passthrough to a 2nd computer display (pass through via the G-RAID).
    Storage:
    –4 TB Tbolt storage, currently the G-RAID looks like a good fit.
    Audio:
    Basic 8-channel mixer. Connect to IO through the breakout cable. Analog audio out to editor monitors and room monitors. Also, occasionally need audio input for scratch VO recording.
    And finally would like to have flexibility to use HDMI output from Canon 5D Mark 3 for studio shoots. Run through the Blackmagic UltraStudio Express into the iMac.
    Ability to record uncompressed YCbCr 422 video
    Guidance on the design of this iMac suite is appreciated.
    Matt Campbell replied 13 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
