Activity Forums Adobe Premiere Pro iMac Running Out of Memory
  • iMac Running Out of Memory
    Posted by Cody Tubbs on April 18, 2017 at 5:18 pm
    Lately I have been running into an issue where my iMac runs out of Memory when working in Premiere Pro CC2017. I thought it was because I was using 4K .mov files so I created Proxies and am using those to edit however I still am dropping down to below 2GB of RAM and Premiere freezes up causing all my other applications to lock up as well.
    What I now believe the issue is would be Sequences within Sequences. Seems whenever I try to adjust a Sequence on another Sequence, my computer runs out of Memory.
    Is anyone else having this issue and have you found a workaround? Or is this a bug within Premiere?
    Here are my operating specs.
    – iMac 5K, 27″, Late 2014, v.10.11.6 with 32GB of RAM, 4GHz i7 Processor and AMD Radeon R9 M295X 4096mb Processor
    – Adobe Premiere CC 2017.0.2
    Cody Tubbs replied 9 years, 4 months ago 2 Members · 3 Replies
  • Cody Tubbs
    April 20, 2017 at 7:03 pm
    That was my first step, I closed out of every other application. Then shutdown and restarted my machine. Then, I made sure only Premiere was open however I still ran into that same issue. I also checked my activity monitor and I have no background memory hogs.
    Another step I took was adjusting the dedicated RAM reserved for other applications within Premiere. At first I only had 3GB of RAM dedicated to other applications so Premiere was running on 29GB of my available 32GB. Then I changed that to 10GB reserved for other applications. Still no solution to the issue. Also I optimized the rendering for “Memory”.
    Cody Tubbs
    – TubbsMedia Productions
    http://www.TubbsMedia.com
  • Jamie Pickell
    April 20, 2017 at 8:27 pm
    Check out this thread I started 3 years ago:
    https://forums.creativecow.net/readpost/3/957622
    Dennis’s note about the number of assets was the answer. I created a new project and only imported my most recent sequence and that eliminated assets I didn’t need. When I bought my own machine, I went with a Mac Pro and put 64GB of RAM in it for this very reason. Long-form edits, particularly documentaries, have a lot of assets so the 32GB limit on the iMac is a bit of a problem.
    Hope this helps.
    Jamie
  • Cody Tubbs
    April 26, 2017 at 8:36 pm
    Hey thanks for the idea about trying to start a new project with only my most recent assets, however that did not work… I am still having issues with sequences inside sequences. When I try to adjust anything on a sequence within a sequence, Premiere locks up and sucks all my machines memory and my whole computer freezes.
    This wouldn’t be such of an issue if I could find a workaround for sequences within a sequence but other than exporting that clip and bringing it into my working sequence I do not know what else to try.
    Thanks tho,
    Cody Tubbs
