Activity › Forums › Apple Final Cut Pro › iMac Pro Configuration Advice Needed
Howie Young replied 6 years, 12 months ago 4 Members · 14 Replies
Daniel Fletcher
September 25, 2019 at 5:12 pmget the base and upgrade the RAM later from OWC when and IF you see performance degrade with lonnnnng sequences. This machine is MORE than adequate for this type of work. You could easily get away with cutting this content on a MacBook Pro or Mini.
IMHO
Save the money for storage and other supporting goods (sound, color, monitoring) -
Howie Young
September 25, 2019 at 7:32 pmHi Daniel,
Thanks for responding. Apple informed me the iMac pro cannot be updated once it is configured and sealed.
Daniel Fletcher
September 26, 2019 at 12:01 amwell of course they would say that. Don’t believe the hype.
https://eshop.macsales.com/shop/memory/imac-pro-2017
Good on you for doing your research on the config and getting other opinions.
Of course get the most machine you can afford, but the core of what Im saying is that you would have more than enough power and memory in that machine to get your work done. You will however probably want some additional supporting storage or equipment that would serve you better than upgrading the GPU etc. the main bottleneck of that machine for editorial is screen real-estate IMHO as great as the display is a second or third is preferredHope this is helpful
Howie Young
September 26, 2019 at 1:13 amDaniel,
Thank you for your advice.
What additional storage would you recommend?
