Activity › Forums › Business & Career Building › iMac Pro
iMac Pro
Posted by Rich Rubasch on December 12, 2017 at 5:57 pmThe new iMac Pro will be available Dec 14th! Any early adopters?
Go!
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
https://www.tiltmedia.comRich Rubasch replied 8 years, 9 months ago 4 Members · 9 Replies -
Shane Ross
December 12, 2017 at 6:07 pmThis guy had it for a couple days…
https://blog.vincentlaforet.com/2017/12/12/apples-new-imacpro-has-an-impressive-200-300-speed-bump/
But really, for $5000 base model, it makes the argument for going for a PC (HP z8) more attractive that ever…and makes the price of them seem reasonable.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Mark Suszko
December 12, 2017 at 7:35 pmThe up-front cost isn’t as big a deal if you depreciate it either 2 years or 4 years. Quite a value, I’d say. Unless… something pops up in real-world use that wasn’t found and fixed in testing.
I have a very nice, older but well-appointed large imac sitting “on ice” in storage, with a full FCStudio setup, because of a blown graphics card, and even if I bought a used or reduced cost OEM card off eBay or someplace now and installed it myself, it’s, financially speaking, almost a wash versus buying a new regular iMac retina at around $2k, considering the rest of the old imac has wear and may manifest other failures… And the OS upgrades may also cause the repair to become moot.
Will the new imac pro manifest any issues with overheated boards or whatever? I’d rather let someone else beta test it for a year or so for me, to find out.
You need it in space grey? I can help you out…
https://www.youtube.com/watch?v=Mn2xKIDMhnQ
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Bob Zelin
December 14, 2017 at 6:31 pmIt appears that the iMac Pro in a useful form will be about $6399 (B&H). If you look at the HP Z31X monitor, it’s
$3999 for that monitor (at B&H) so $6399 for the “complete system” is a pretty good deal. The Mac includes for that price the Vega 64, 64 Gig RAM, and the 10G card (and the monitor).I mean – we do want to compare “apples to apples” (pardon the pun).
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com -
Rich Rubasch
December 15, 2017 at 4:34 pmJust ordered two identical 8 core with 64 gig of ram and the 1TB SSD. Seems like the internal SSD is a screamer at 3GB per second max. Mainly getting these for the 10gig ethernet to go with a Qnap 12 bay NAS (8 drive and four 2.5″ SSD) which has two 10Gige ports plus four gigabit ports. We have 8 Seagate Constellation E3 2TB drives and will go with a RAID 5 config.
Should suffice just fine.
We will pair the two iMac Pros with the Dell Ultrawide 34″ monitor which is the exact same vertical height as the iMac and same vertical resolution at 1440. Total monitor horizontal width is 57″! Not sure how that will be with so much horizontal width!
https://www.bhphotovideo.com/c/product/1112687-REG/dell_ultrasharp_u3415w_34_3440x1440.html
Aja 4k I/O will be the outboard video device (we are all LHI’s currently).
More to come once they ship!
Rich Rubasch
Tilt Media Inc.
https://www.tiltmedia.com -
Bob Zelin
December 15, 2017 at 5:10 pmhow will you connect the Dell 34″ monitor to the iMac Pro ?
or is that for your HDMI out for your “program monitor”.Bob Zelin
Bob Zelin
Rescue 1, Inc.
Rich Rubasch
December 15, 2017 at 9:09 pmWe are assuming a thunderbolt 3.0 to 2.0 adapter and then thunderbolt to Display port to the monitor.
The Aja IO will downconvert to HDSDI which will feed our Panasonic Plasma 1080 monitors and studio Panasonic and or JVC LCD professional monitors for viewing.
And for fun, if we actually cut a 4K project I have a Seiki 65 inch 4k monitor hanging on the wall and can take the AJA IO out to that as well.
Oh what fun…
Rich Rubasch
Tilt Media Inc.
Rich Rubasch
December 15, 2017 at 11:58 pmHey Bob…why does the Qnap have three HDMI ports on the back? Also it has internal M2 memory card slots for very fast caching…do you recommend adding those if only 2 or 3 people are using the drives?
Rich Rubasch
Tilt Media Inc.
Bob Zelin
December 17, 2017 at 4:46 pmThe QNAP can run as a virtual machine (you load windows onto it when you create a virtual machine) and you will then have 3 monitors. The HDMI out’s are for playout, if you want to use this as a plex server, or use Video Station. You don’t have to play back on your computer monitor. With that said, I have never tried to use the HDMI ports ever, and I actually don’t know how to setup a VM on the QNAP.
No, I don’t recommend the M.2 for caching for video for 2 – 3 people. I have not tried Qtier, but I have tried normal caching with the QNAP many times (with TVS-1282T, and TS-1685) and it does not increase performance for video editing.Bob Zelin
Bob Zelin
Rescue 1, Inc.
Rich Rubasch
December 18, 2017 at 11:19 pmAwesome…thanks Bob!
Rich Rubasch
Tilt Media Inc.
