Activity Forums DaVinci Resolve iMac NVIDIA GeForce GTX 680MX DaVinci Resolve performance is Amazing
  • iMac NVIDIA GeForce GTX 680MX DaVinci Resolve performance is Amazing
    Posted by Paul Jay on February 27, 2013 at 1:40 pm
    I’m lost for words. The performance is incredible. I haven’t been able to make it dropped frames with 10 Nodes with blurs on ProRes.
    Not really sure how this candle test works exactly, but i would like to test it.
    I’m blown away by the performance of this iMac 27”
    Didier Martinez replied 12 years, 9 months ago 10 Members · 17 Replies
  • 17 Replies
  • Margus Voll
    February 27, 2013 at 2:30 pm
    what material and on what resolution ?
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Jason Osterday
    February 27, 2013 at 3:51 pm
    What specs on that iMac?
    The candle test should have a clip of a parrot (SD resolution) and you simply jump through the different versions to do anywhere from 04 to 64 blur nodes. Check it out and see what you get.
  • Paul Jay
    February 27, 2013 at 4:22 pm
    ProRes 422 1920×1080 25fps
    I’ve tested BMC RAW footage as well.
    I get full playback with 5 blur nodes……On an iMac.
    Sweet.
  • Paul Jay
    February 27, 2013 at 4:26 pm
    I have found the parrot clip and the project.
    But it has only 4 nodes with blurs.
    What do you mean with jump through different version?
    It’s a 27” iMac 3.4 Ghz i7 Quad Core – 1TB Fusion Drive – Nvidia GTX 680 MX 2GB – 32 GB RAM ( kingston)
    Don’t buy extra RAM at Apple. you can add 3th party.
  • Margus Voll
    February 27, 2013 at 4:38 pm
    Really good option for home small indy stuff then
    Margus
    Multibridge 2 Pro
  • Paul Jay
    February 27, 2013 at 5:09 pm
    Indeed. Hook up a Thunderbolt Ultrastudio Express for SDI and HDMI monitoring and you’re good to go.
  • Sascha Haber
    February 27, 2013 at 6:08 pm
    When you right click the one thumbnail in the timeline you should bring up a menu where you can select 8 versions.
    The noes will double every time and then Noise Reduction nodes will be added.
    Switch to a version and let it play, then write down the FPS count and share with us.
    I am very curious to see those numbers as my MacPro is dead now and Apple wants to replace it with an iMac.
    A slice of color…
    Resolve 9.1.1 OSX 10.8.2
    Colorist / Aerial footage producer
    https://vimeo.com/saschahaber
  • Margus Voll
    February 27, 2013 at 6:25 pm
    What do you mean dead?
    I have had soma anomalies now but after i replaced my os drive with ssd’d
    Margus
    Multibridge 2 Pro
  • Sascha Haber
    February 27, 2013 at 6:38 pm
    I mean that it was in service three times now for the same reason and they acknowledge that they are unable to fix it.
    They changed the main-board twice, the CPU one time and the last time they changed the logic board in the cinema display.
    Who am I to tell them that it must the be the capacitors in the PSU…just because my TV had the exact same problem 😉
    The computer does not wake up from sleep properly and I have to shut it down…all work is lost.
    It also needs two boot attempts every single time.
    Anyway, because the MacPro is officially not on sale anymore in Europe there are talks about offering me an iMac instead.
    So I would like to see the numbers of the Standard Candle test if possible.
    A slice of color…
  • Margus Voll
    February 27, 2013 at 6:43 pm
    Yes please. I would also like to know.
    Margus
    Multibridge 2 Pro
