Activity › Forums › Apple Final Cut Pro Legacy › iMac, Lion, & Final Cut 7 – Playback Sync Issue
Kiko Matsing replied 14 years, 6 months ago 6 Members · 12 Replies
Matt Wainwright
March 27, 2012 at 2:52 pmIt also happens when timeline and media are in the same codec, yes. And on multicam playback too.
Kiko Matsing
March 28, 2012 at 4:33 amI have also experienced this using MacPro and iMac, different timeline compression setting and different video footage codec. I noticed that even i change already my edit, then render it, seems FCP is still reading the old rendered audio and video files on the scratch disk. By deleting them and rendering all again, it alway solve my problem with the syncing. But i have to make sure i deleted everything including my misplaced audio and video renders on other scratch disk. (sometimes i forget changing my scratch disk with other projects) You can try if it works with you.
