Activity Forums Apple Final Cut Pro Legacy iMac, Final Cut, and External monitor — HELP!
  • iMac, Final Cut, and External monitor — HELP!
    Posted by John Miller on November 26, 2009 at 12:49 am
    Hi, I tried searching but didn’t find what I’m looking for.
    I have a mid-2007 iMac that has a mini-DVI output port. I’m getting an LCD
    widescreen (full HD) monitor and hook it up to my iMac using the adapter.
    When I’m cutting in Final Cut Pro 6.0, I want to move the Canvas over to the
    external monitor, and expand it so I can see my picture larger..
    That is not the problem, but, when I go to full screen (command + F12) can I see
    the full screen on my external monitor, or would it still show on my iMac?
    I know I can go up to View>Video Playback> and choose Digital Cinema Desktop Preview Main
    When I attach and configure my other monitor, will it show up in the Video Playback menu?
    I assume that if it does, I will be able to preview full screen on that monitor now.
    Thank you for any help or suggestions.
    John Miller replied 16 years, 9 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    November 26, 2009 at 12:30 pm
    The LCD is a TV set or a computer display?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • John Miller
    November 26, 2009 at 7:40 pm
    Hello Jerry,
    The LCD is a computer display. I will connect it using a mini-DVI to DVI adapter from my iMac to the LCD display.
  • Jerry Hofmann
    November 27, 2009 at 12:40 pm
    You will be able to choose either monitor for full screen playback. But it won’t be exactly what you’d see on a TV set because the gammas are different between the computer display and a video monitor or TV set, so it’s not the best for color correction. If the source material is interlaced, then it will sort of tear during playback because a computer display is progressive only. There are fixes for this, but just keep that in mind…
    Jerry
  • John Fishback
    November 27, 2009 at 5:58 pm
    Here’s a post that might relate to your question. I don’t know if your iMac’s display card does any “cleaning up” of the signal. https://forums.creativecow.net/readpost/200/883587
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Miller
    November 28, 2009 at 5:44 am
    Thanks Jerry and John.
    All I need it to do is playback in full screen.
    Thanks for your help
