Activity Forums Apple Final Cut Pro Legacy imac dvi video out – for external monitoring in FCP
  • imac dvi video out – for external monitoring in FCP
    Posted by Stephensf on August 14, 2007 at 8:16 pm
    I hope no-one will shout at me for trying to use an imac to learn colour correction on! I am just learning before using the proper setup at work.
    However, I am trying to learn some basic colour correction stuff and obviously I need to hook up an external monitor.
    The way I thought I would do this at home is via some form of dv cam attached to the firewire of my computer then playing out to the pal monitor.
    But, as I am in the process of buying an imac which has a mini dvi out, I was wondering if I could use this to hook up a monitor for external monitoring.
    Anyone know if this is possible?
    Thanks in advance
    Stephen
    Stephensf replied 19 years, 1 month ago 2 Members · 2 Replies
  • 13 Create COW Profile Image
    13
    August 15, 2007 at 2:19 am
    It will not give you accurate color representation.
  • Stephensf
    August 15, 2007 at 6:09 pm
    Do you mean it would not give accurate colour representations in either situations ie, using a firewire device out to an external monitor, or, using the dvi out on the mac?
