Activity › Forums › Apple Final Cut Pro › iMAC and FCP X
iMAC and FCP X
Posted by Russell Hossain on December 21, 2011 at 5:49 amCan iMac Play Canon 5D mark II footage (1920 – 1280) real time in FCP X and Apple color 1.5?
Russell Hossain replied 14 years, 8 months ago 4 Members · 4 Replies -
Kevin Patrick
December 21, 2011 at 12:48 pmDepends on what iMac.
The current fastest iMac is quite capable.
https://barefeats.com/macs11_01.html
Bill Davis
December 21, 2011 at 5:41 pm[Russell Hossain] “Can iMac Play Canon 5D mark II footage (1920 – 1280) real time in FCP X and Apple color 1.5?”
Generally yes. (knowing that “an iMac” is a thing of variable configurations!)
FCP-X works best when you allow the recommended “transcode to ProRes 422” upon ingest – which re-wraps the fundamental H-264 5d footage into a form that FCP handles really well.
But I have popped “native” 5d files on a timeline and they work fine unless you muck them up with bunches of filters and overlays and such. If you want to do that, you’re better off going the ProRes route, since it’s something X “speaks” even more fluently.
FWIW.
“Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Russell Hossain
December 24, 2011 at 8:32 pmOk good. One of my friend told me to Log and Capture footage from camera or memory card in FCP with ProRes 422 easy setup. But what is the best procedure to keep best color result?
