Activity › Forums › Adobe After Effects › I’m trying to move the texture inside the luma matte but it doesn’t work
Posted by Nitai Lev-oren on April 30, 2019 at 7:25 amNitai Lev-oren replied 7 years, 4 months ago 4 Members · 6 Replies -
Richard Garabedain
April 30, 2019 at 10:06 pmit is working isnt it? the gold has taken on the shape of the text
Nitai Lev-oren
May 1, 2019 at 2:50 pmno. because the texture is bigger and if I move it it doesn’t change on the txt
Max Haller
May 1, 2019 at 8:47 pmWeird it does seem like it’s working. Have you tried moving the texture underneath by changing the x,y coordinates in the position property instead of dragging with the mouse?
The only thing i can think of is something is stopping the layer from moving somehow. try moving it through the position property and if that doesn’t work try using the transform effect to shift it over.
Wang Ruixin
May 2, 2019 at 5:08 amHi there.
First, you should make sure your text is pure white.https://videohive.net/user/untruelife
Nitai Lev-oren
May 2, 2019 at 6:31 amI moved it on the X and Y I did it all it doesn’t change.
I realized it’s because the gold is a Layer style made in photoshop I think it’s because of that…
so I do I flatten the layer? (not in photoshop)
