Activity Forums Adobe After Effects I’m trying to get rid of the grouting in the tiling (on the floor) in this video
  • I’m trying to get rid of the grouting in the tiling (on the floor) in this video
    Posted by Eli Jordan on August 22, 2021 at 12:50 am
    Here it is: https://youtu.be/rMWnGnctgcs
    I used the paint tool on the first frame of the raw footage to clean up the tiles: https://imgur.com/jLzlQ34 But it’s very difficult to get the paint to track to the footage.
    What’s the best way to go about this? Is it possible to do flawlessly?
    Thank you in advance.
    Eric Santiago replied 5 years ago 3 Members · 2 Replies
  • Greg Gesch
    August 22, 2021 at 11:14 pm
    Hi Eli, I would try with the CC Simple Wire Removal effect and use several instances. You might even be able to manually keyframe the beginning and end points of the effect as the shot pans.
  • Eric Santiago
    August 23, 2021 at 1:00 pm
    The camera moves smoothly enough for you to track using Mocha or just manually with a 3D Camera heck even keyframe a mask but that’s a bit of work.
    But you will need to do some cleanup to reclaim the foreground elements.
    Some shadows to work around with but no reflections so its easier.
    What are you planning to replace it with?
    Same color flooring?
