Activity › Forums › Adobe After Effects › Im sure there is a simple fix or answer to my problem…
  • Im sure there is a simple fix or answer to my problem…
    Posted by Andrew Armstrong on August 11, 2006 at 11:09 pm
    I have a Comp with some video in it. I’ve been given another AE project which is alittle animated logo. I’ve brought it in as another Comp but its smaller than Comp with the video in it. When I go to really blur it out or add some light rays they get cut off by the edges of the comp. Is there anyway to fix this so the blur or light rays extend PAST the edges?
    Andrew
    Andrew Armstrong replied 20 years, 1 month ago 2 Members · 3 Replies
  • Graham Quince
    August 12, 2006 at 7:09 am
    Use the Grow Bounds filter in AE. Put it before your blur and you should get the result you need.
    Alternatively, choose Layer>Pre Compose… on your smaller comp. After Effects will make a new comp the same size as your final comp containing the smaller comp. You can now apply the effects and they should work too.
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Andrew Armstrong
    August 13, 2006 at 8:54 am
    awesome thanks! Ill try it out later today.
  • Andrew Armstrong
    August 13, 2006 at 8:48 pm
    Pre-composing worked perfectly! Thanks!
